33 Powerplay / -2 lowers
Old 06-21-2015 | 02:38 PM
Default 33 Powerplay / -2 lowers
Contemplating some -2" imco/sportmasters on my boat, currently has standard length and the prop shafts are 5" below the hull when parallel to it. No stand off boxes at this time, does anyone have any experience with this setup or similar? I'm hearing 3" below hull is the sweet spot for these hulls.
AJ POWERPLAY is offline
Old 06-21-2015 | 02:49 PM
Indy's Avatar
Member #154
JROMY had the last PP built, it had 525s with stock 32s and ITS/sport master drives on it. It ran solid 89 with no mods. I'm sure with some tweaking that boat would have been a 90+ mph boat. I was in it many times.
Indy is offline
Old 06-21-2015 | 03:14 PM
He was on salt though wasn't he? ITS also adds 7" stand-off. I'm running 85 right now fresh water spinning 30's.
Old 06-21-2015 | 06:08 PM
Take away 2" from your lower unit and we will call you Caitlyn.
JRider is offline
Old 06-21-2015 | 07:41 PM
Starting at a similar X as you, each 1" higher we raised the X was worth about 2 MPH.
BenPerfected is offline
Old 06-21-2015 | 08:27 PM
Your boat runs good! You ran next to you a few times at the spring run. Hoping someone has some knowledge or a pair for sale, haven't had much luck in the wanted section.
Old 06-21-2015 | 09:04 PM
Running in the bumps your boat has a really good attitude. You will/may have deal with a few things with the prop shafts being higher. The boat will be some slower getting on plane and you will likely need to get your props tweaked to add some additional cup.
Old 06-21-2015 | 09:46 PM
I was thinking about going to a five blade setup with shorties, but then again I may just get a new pair of 30's and have Bblades tune them in, I had good luck with them before. I think if I go to five blades I'm going to have to take my drives back to All-American and go one stage higher.
Old 06-22-2015 | 06:40 PM
Short tube maximus might work. The first thing I would do is try it with what you have or can borrow from a jacka$$ like me
JRider is offline
Old 06-22-2015 | 07:09 PM
I doubt you will need 30P. It will cost you in acceration vs. the 28P. The RPM should be still be similar as you have now but you will pick up speed by having less slip with your reworked 28P. IMO, the 5-blades are harder on the drives especially as you come in and out of the water. Good conversation to have with Brett.
