Quick Rinda mercruiser question 555 adaptor >
Old 06-22-2015 | 08:09 AM
Default Quick Rinda mercruiser question 555 adaptor
I only have the mefi1-4 (10 pin) adaptor for my Rinda scan tool. I want to be able to also read a 555 computer (496 HO).
A buddy's Engine is acting up once a day. Just 1 beep then the port engine cuts out for 1/2 second when running over 3500-4000 rpms. All gauges read fine and performance is fine.
Do I just need the 94006 adaptor or do I also have to upgrade my software?
Thank you in advance.
92nsx is offline
Old 06-23-2015 | 01:39 AM
Roughly how old is your scan tool? You may have to call Rinda direct as they have good phone support.
http://www.rinda.com/company.htm
lakematdude is offline
Old 06-23-2015 | 12:16 PM
It is older not sure of the exact year, but I would guess 10 years?
92nsx is offline
Old 06-23-2015 | 01:07 PM
Sydwayz's Avatar
Forum Regulator
Yep, just call Rinda. They are excellent and knowing exactly what's needed. You will likely need to give them the Firmware/Version of your Scanner, and know the year of the motor you want to scan.
Sydwayz is offline
Old 06-23-2015 | 05:46 PM
Ill give them a call tomorrow. 2003 model i think at least that is what it says on the start up screen along with version 4.03.
92nsx is offline
Old 06-23-2015 | 10:05 PM
BUP
2.7 and 6.0 are updates for older Diacom units.
BUP is offline
Old 06-24-2015 | 07:36 AM
http://www.boatfix.com/merc/Bullet/01/01_01.pdf
This bulletin replaces bulletins 96-9 and 93-23. Destroy these older bulletins.
MerCruiser Scan Tool
Version 4.0
This hand held Scan Tool has been updated for 2001. It can be used on all gasoline MCM/
MIE engines equipped with either the Delco MEFI ECM or the new Mercury PCM 555
Looks like I just need the 94006 adaptor
92nsx is offline
Old 06-24-2015 | 11:08 AM
Yep . That update has me reading 555s no prob . Didnt fix the glitchy backlight though..
airjunky is offline
