Complete #4 upper housing with all internal components
#4 upper housing with all parts. 1.48:1 upper gear set installed, but I have a new 1.31:1 poly set for it also.
$2500 as is or $4500 with a new 1.31:1 straight cut net forged poly gear set.
Gary
612-247-7081
Gary
612-247-7081
I ran #5's (factory rated for 750hp) on my heavy 38 flat deck Cigarette with twin 1100hp PSI blown BBC and had absolutely no trouble with them for years. The #4 is basically the same with a slightly smaller bearing. They, the #4, were used for many years in both pleasure and racing applications, so there are still parts around for them. I would not be afraid of using a #4 behind a 800-900hp engine. In my opinion there is no comparison to the Bravo XR. You could not give me a boat with any Bravo drive, if you were going to deviate from a stock Mercury low performance engine.The Bravo will not hold up. My opinions only.
