what is the best prop for a 35 fountain with 525's
I just bought a 2005 35 fountain with side by side 525's and ws wondering what is the best prop setups. I was thinking maximus or p5x. It has 31 pitch custom labbed bravo ones made from 30 pitch castings with a 1" drive spacer. I was thinking of removing the spacer and going to a 5 blade prop.
John
John
I have the same boat. Bblades recommended labbed 34P Bravo 1s. I'm still running the 32P Bravos. Depends on what you are looking for. 5 blades have better mid range and handling. I would remove the spacers like you said.
Ran 86.1 on the limiter with labbed 30 pitch bravo 1 props and 1" spacer 3" below the bottom. Bought p5x props ran 90.3 with 30 pitch props and 1" spacer. Going to remove the spacer and see how it does mind you this is all in 90 plus degree weather. Also sending the ecu's to precision marine for the reprogram and raised rev limiter because both props hit the limiter. Trying to document and do each step to see what works.
