Trim tabs indicator cables.. >
Old 06-29-2015 | 08:08 AM
Smitty's Avatar
Default Trim tabs indicator cables..
I have a 36 Outlaw and the starboard cable is frozen. And while I am there I am going to do the port side as well. So if anyone knows how long and what to buy, that would be awesome !!! I have been told to look on the cables for the length. Meaning I have to pull them before ordering...I would like to avoid that if possible.
Thanks !!!
Smitty
Smitty is offline
Old 06-29-2015 | 10:02 AM
Call Baja and ask? Might need you HIN for verification.
Cole2534 is offline
Old 06-29-2015 | 09:35 PM
Smitty's Avatar
Baja has been closed for many years now...
Smitty is offline
Old 06-30-2015 | 10:45 AM
So has Fountain but the new tech support is rather helpful and they're somehow in cahoots.
Otherwise I think you just need to pull them. I found that the 12' Merc cable was a little longer than the 12' Teleflex I ordered as a replacement. I had to adjust a couple things to make it fit.
Cole2534 is offline
Old 06-30-2015 | 11:01 AM
You might try buying some plastic tubing from hardware store and running it alongside of cables cut or mark it to proper length/s remove and measure.
GLENAMY 242SS is offline
