Water in a the bilge on a 2006 rage????
I'm getting water in the bilge and I'm trying to figure out as to where it is coming from? When out all day I have I can turn the pump on a couple of times and water will pump for about 3 to 5 seconds. Can it come from large waves splashing on to the swim deck and going into the vents under the sun pad?
If you were hit in the stern by a wave large enough to come up and over the swim platform, you would know it. My swim platform eats some large waves when we are anchored and careless drivers speed passed, I have never had water up and over. How much in and out of the boat do you do? Wet swimmers can account for some, but not typically 3-5 seconds of bilge running. Are you noticing the water after running her? You do have a water pickup on the outdrive, right? At idle, a raw water pump won't move too much fluid, but at speed, lots of water moves through. Maybe a small leak somewhere in the system.
Are you certain you do not have a cooling water leak when running? I was getting water in my bilge but the inner transom was dry, and it didn't leak when sitting still.
It also didn't leak visibly at idle. It wasn't much so I didn't worry about it.
I was changing an impeller a few months after I noticed regular small amounts of water in the bilge, and happened to brush against the fitting for my water pressure gauges while I was tearing things apart,and it dripped water off the side of it. The brass fitting had cracked. It was probably only leaking at over 10-15psi of water pressure.
Many, many years ago, I replaced the SWP impeller on my HP500EFI. I didn't get a good enough visual inspection on the inlet hose when I was reinstalling, and did a poor job of putting the hose all the way on the barb, yet I had torqued down the hose clamp pretty well. I actually put a little pucker in the hose. After a nice long cruise, the auto bilge came on. That time, I was able to see water pouring in when I was idling and in the water. When I had run it on the hose after the installing the SWP, there was no water in the bilge.
I had a similar issue with water migrating in the bilge. Turns out my issue was the seal around the exhaust tips. I had the angled tips that were flush mounted and they got loose and water was getting in from there. I have also had water enter the vents on either side of the swim platform when a large tubing wake hit me while I was sitting still.
Good luck..
Good luck..
Going to put in the water tomorrow and check it before I take off and then while running. I hope I find it as my mom got me a slip to use at her yacht club for the three day weekend, no trailer action for three days, yahooo!!
