33 AVS Bilge Leak >
33 AVS Bilge Leak
33 AVS Bilge Leak
Old 06-30-2015 | 11:56 AM
Default 33 AVS Bilge Leak
I'm taking on a small amount of water in my 1999 33 AVS, but can't figure out where it's coming from. When I repowered this past offseason, we redid all of the hoses and equipment, so there's a very small chance that it's something to do with that. Also, when the engines were out, I put it in the water and left it there for a half hour or so - not a drop was there.
However, I'm wondering if any other 33 AVS owners (or owners of boats with similar swim platforms) think it may have something to do with water coming onto the swim platform when I come off of plane. Even if I'm careful, some water comes onto the platform, and there is a vent only a few inches above it on both the port and starboard side that goes to the engine compartment. Could a little water be coming in then? Has anyone had a similar experience? Thanks for your feedback.
chris21hope is offline
Old 06-30-2015 | 01:35 PM
I was also taking on some water and could not figure it out. You are probably correct. Mine was coming in the side vents while floating with the large boat wakes.
Run it on the hose. If it is a hose or clamp you will find it. If nothing then it's unlikely the plumbing and more likely vents or other hull parts.
Crowney is offline
Old 06-30-2015 | 04:08 PM
Team Archer's Avatar
also check the little bellows on the shift cable they are notorious for leaks.
Team Archer is offline
Old 07-01-2015 | 09:17 AM
scarabman's Avatar
K Plane indicator cable bushings also leak sometimes as the get older.
scarabman is offline
