!989 BAJA sport 240 Chine walking! IDEAS?! >
Old 07-04-2015 | 12:02 PM
Thumbs down !989 BAJA sport 240 Chine walking! IDEAS?!
i have a 1989 baja sport 240 with a 509 bbc. Im having a hard time keeping my boat straight at high speeds. When running 64+ the slightest little thing sends my boat completely out of control. I have K planes on it to try helping but it still doesn't work. Seems like as soon as you open it up it starts chining BAD! Any suggestions? There isn't play in the outdrive either. Any help would be greatly appreciated.
chevroletbbc is offline
Old 07-05-2015 | 05:38 AM
I had the same problem, after I installed full hydraulic steering it went away
conneroutlaw is offline
Old 07-05-2015 | 07:21 AM
What prop are you running? About the best prop out there for the 24 outlaw/ 240 hulls is the mach 4 blade if you can find one. Bravo's throw the boat around to much. Raising the outdrive makes a huge difference in handling of the boat as well. The drive is in the basement. I raised my old one 3.5" and it still never had issues with blow out with a 4 blade.
wfo1 is offline
Old 07-05-2015 | 09:19 AM
What external steering did you go with? An I'm running a bravo 1 4 blade 24p. Also the hook has been removed from the bottom of the hull.
Old 07-05-2015 | 07:15 PM
The hook in the strakes can't be removed, it has to be filled in. I know of guys who paid thousands to get it fixed after "removing" the hook. I have zero chine walk on a 25OL with a warmed up 525sc, Imco full helm single ram, 280 kplanes and an extension box
JerseyOutlaw is offline
Old 07-06-2015 | 05:04 AM
I am running a sternellie 4 blade prop, lobbed and cupped, not sure on the pitch, when I bought the bought from an idiot he had no idea what the pitch was on it and the prop is not marked. I have a 502 w a m1 procharger w 8lbs of boost. The boat does 80 mph on the gps
Jj
Old 07-06-2015 | 05:07 AM
I bought a imco full hydraulic steering unit, I am very happy with for a few reasons. The price, replacement parts, the quality of the parts used. You get your moneys worth out of it, no issues yet, and chim walking went away
Jj
