Harness
Old 07-05-2015 | 08:27 AM
Default Harness
Just curious where I would begin to look for the harness from the engine to the helm. Buddy has a 1990 25 baja with a single. He has mentioned wanting to replace it. Is that a harness that can be bought or should it just be rewired? What's your opinions? Also I'm not sure why he wants to replace it we were just talking about it.
Thanks for any help.
Crude Intentions is offline
Old 07-05-2015 | 08:31 AM
Tinkerer's Avatar
I just rewired my complete boat. It is repairable unless the plug itself has burned contacts. Is there a boat junkyard or a marina that has some old boats sitting on there back lot? They may be willing to sell him what he needs.
Tinkerer is offline
Old 07-05-2015 | 08:35 AM
I have one from a 23' Maxum 1999 if you end up needing it.
GLENAMY 242SS is offline
Old 07-05-2015 | 09:12 AM
Mbam's Avatar
Offshoreonly Advertiser
I am assuming that is the old style with the rubber plug? Mercury sells it 2 ways, one is nicely terminated at the helm end with all the connections labeled. Can be a bit messy under the dash as the lengths are not exactly what you need unless of course you cut the ends off and put your own connectors on. And is "bare" meaning there is no jacket around the individual wires. Just a long group of wires, comes 3, 20 and 25 feet 812475Ax (x = length)
It does make life easier as there is a power, sender and ground lead for each gauge.
The other way is called intrument extension harness. It has a nice jacket around the wires, a male plug on one end and a female on the other. But you have to cut it to length and do your own connections. 10,15,20,30 and 45 feet. 812441AXX
Mbam is offline
Old 07-05-2015 | 04:59 PM
I found a REALLY clean harness on EBay for a great price. I also found an engine harness that was like new.
Jonesyfxr is offline
Old 07-05-2015 | 06:54 PM
Hey Mike, try this.
http://bpi.ebasicpower.com/c/ALL6I/I...anel+Harnesses
MILD THUNDER is offline
Old 07-05-2015 | 07:05 PM
14 apache's Avatar
I would not buy a used harness a few I had where bad and looked new. There is more than one style round plug the early one had a amp meter make sure you get the rite one. The stock one is a nice
14 apache is offline
Old 07-05-2015 | 07:09 PM
Thanks guys. Sent all the options to my friend.
Old 07-07-2015 | 12:08 PM
ICU Lookin, try these ones......
http://www.marlanindustries.com/prod...ngharness.html
http://www.hardin-marine.com/c-1230-...harnesses.aspx
