MerCruiser Gil exhaust manifolds What motors did these come on? >
Old 07-05-2015 | 09:00 AM
Default MerCruiser Gil exhaust manifolds What motors did these come on?
What motors did Merc put these manifolds on, any idea what year range they were used?
Thank you in advance.
GLENAMY 242SS is offline
Old 07-05-2015 | 09:12 AM
They were on a wide range of years but stopped IIRC with the HP500 around 99/2000 with the HP500efi and CMI E-Tops. Merc 420s in the late 80s I think had them first. If not it was the HP465s
endeavor1 is offline
Old 07-05-2015 | 11:55 AM
Mcm 440 &460 had gil aluminums and i dont believe those were the mercruiser rebadged either .i believe those were early hp500 and bulldog . Look for seperate hose going to riser they had a few early units with cast riser going to stainless pipes, larger wet joint system
airjunky is offline
Old 07-05-2015 | 12:53 PM
Merc 420, 525SC, 600SC, carbed HP500 and probably several others used the Merc/Gil exhaust.
Griff is offline
Old 07-05-2015 | 01:06 PM
HP450's also used them
JaayTeee is offline
