Converting Merc control box to Hardin Marine Throttle >
Old 07-06-2015 | 02:19 PM
Default Converting Merc control box to Hardin Marine Throttle
Just ordered this to replace my worn out single stick Merc throttle control box.
Can't wait until in arrives.
http://www.hardin-marine.com/p-74408...e-control.aspx
Will post some pics of the before, during and after.
Jeff B In Maine
Rubrsidedown is offline
Old 07-13-2015 | 08:29 PM
Single stick control...
From this
To this.
Stay tuned.
Hope to have it installed and finished this week for smooth boating from here on out.
Jeff B In Maine
Old 07-13-2015 | 10:46 PM
I have seen those in print never in person and always wondered .
Once you get used to it ill bet you like it . Eventually you will really really like it
airjunky is offline
Old 07-16-2015 | 01:58 PM
Knot 4 Me's Avatar
I will be interested to hear how it is to shift from reverse back up to neutral. From the pic it appears the throttle might interfere with a clear grab of the shift handle.
Knot 4 Me is offline
Old 07-24-2015 | 05:24 AM
Sorry for the delay.
Here are a few pics.
It's not 100% finished just yet but very close.
Time to drill and cut a little fiberglass.
Dry fitment, wiring it all up soon.
(Warning sticker removed.... Should have done that years ago)
Not sure when I will be wet testing as this weekend is a busy one for us AND the weather isn't cooperating very much.
High of 69 degrees this weekend... with showers YUCK!!!
I don't think there is or will be any issue or problem going from rev to neutral or forward.
Sure, it'll take a little time getting used to it but to go into and out of gear should be much easier with this system compared to
the single Merc unit that was removed.
Certainly a few hundred $$$ more than a stock replacement but all in all I think it was a no-brainer.
Outdrive is coming off to replace the shift cable and service it.
Should be good to go by the time warmer weather finally shows back up.
Jeff B In Maine
Old 07-24-2015 | 07:48 PM
Here's a behind the throttle photo
O
Old 07-25-2015 | 08:20 AM
If that orig commander control box still works it has some value for sure
airjunky is offline
Old 07-25-2015 | 08:23 AM
It does and it comes with cables. 13' throttle cable and a 14' shifter cable. (Not gen II style though).
Old 07-28-2015 | 09:13 AM
O
Plenty of room to operate. =-)
Old 09-09-2015 | 10:16 AM
Update on new dual stuck control.
I've had some seat time with it and have easily leaned the new controls.
Simply, the VERY best!!!
Couldn't be happier with this set up.
Well worth every penny.
