Test drove a LBZ. Now have questions.. >
Old 07-07-2015 | 04:29 PM
Default Test drove a LBZ. Now have questions..
I have zero diesel experience so bare with me.
Pulled eng dipstick and oil was black.. Is that normal?
Going full throttle while cruising at abt 30 mph, tranny down shifted twice, then up shifted, then down shifted, then up shifted.
Are 6-speed Allisons supposed to act like that?
After abt 2 seconds of full throttle, I could feel a faint miss. Could this be just a fuel filter replacement?
The truck does not smoke at idle or at full throttle.
zz28zz is offline
Old 07-07-2015 | 04:48 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Does the truck have a tuner on it?
How many miles?
Diesel engine oil will be black, especially if it has a tuner on it.
Sydwayz is offline
Old 07-07-2015 | 09:06 PM
No tuner.
100K miles.
zz28zz is offline
Old 07-08-2015 | 04:25 AM
I am no expert but my dad has similar truck and I am fairly sure if you go WOT it downshifts once (maybe twice) not sure why it down-up-down would happen normally. Also when his is in need of a fuel filter the power is down linearly , no perceivable miss, just less power .
happy hours is offline
Old 07-08-2015 | 10:25 PM
Thx! That's what I needed to hear. I'd hate to spend $25k+ just to find out the eng/tranny is bad.
Any tips on what to watch out for when buying a LBZ equipped truck would be appreciated.
zz28zz is offline
Old 07-08-2015 | 11:00 PM
Rwbrew3's Avatar
Nope - Great engine tranny package, fuel filters are regular maintenance with the duramax, and oil is always black regardless. Only downside if is a 3/4 ton ( depending on year ) is it is a rough riding truck' I would look into some better shocks if factory - I did the blistering 5100's and that helped out, put a load on it and it's great. Also, everything about diesels is more expensive - just a FYI !! Good luck !
Rwbrew3 is offline
Old 07-08-2015 | 11:48 PM
Formulabill's Avatar
Go to Diesel Place .com, this is a G.M. site and check out the forums. Your LBZ has its own section and they will answer all questions you can think of.
Formulabill is offline
Old 07-09-2015 | 10:14 AM
Quinlan's Avatar
[ATTACH=CONFIG]542904[/ATTACH]
Love my 07 classic LBZ 95K on it now. 3500 Srw CC Only issues I have had are front end things. And I am pretty sure that is because I have 20's and too wide tires.
But It LOOKS good lol
chitty pic
Quinlan is offline
Old 07-09-2015 | 08:04 PM
Thx for the link to Diesel Place. Lots of good stuff. The "10 Most Frequent Problems With an LBZ" thread was especially helpful.
I've heard abt the fuel filter situation between Chevy and Isuzu. Read a couple of threads that suggested adding aftermarket filters and lift pumps. Not sure if that is necessary or not for a LBZ.
A 2007 Classic LT3 LBZ is exactly what I'm looking for. The GMC equivalent (Sierra SLE??) is a pretty sharp looking truck too. Either would work. The search continues..
zz28zz is offline
Old 07-09-2015 | 08:08 PM
When my duramax would "bog down" under hard acceleration it meant it needed a fuel filter change......I got about 10K miles out of a delco factory filter after the low sulfur fuel came out.
Jupiter Sunsation is offline
