575 Sci head gasket work ? >
Old 07-09-2015 | 07:10 PM
Default 575 Sci head gasket work ?
Blew a head gasket so was wondering what else I should change while i'm in there and what should I check..
Thinking scorpion racing rockers, push rods and springs.
Thank you
outlw36 is offline
Old 07-10-2015 | 07:20 AM
I just had mine done - ....everything in there was replaced.
Cometic head gaskets
head bolts
valve springs
10* steel retainers
10* valve locks
-Fluor-elastomer seals
roller rocker arms
pushrods
billet double roller timing set
pressure test headers and tails
I did roller cams too - so that added a few more parts, but just plan on replacing all components in the heads.
ALL_IN! is offline
Old 07-10-2015 | 07:44 AM
head bolts
valve springs
10* steel retainers
10* valve locks
roller rocker arms
pushrods
Yep thats the way to go... Do yourself a favor & do as Easyrider did
Bawana is offline
