Help Please - re-jet 454 merc carb >
Old 07-10-2015 | 09:14 PM
dna
Default Help Please - re-jet 454 merc carb
Below is a pic of the carb that I removed from my 92 Sleek, with a 454 merc. I believe it is stock - can someone please confirm. My question is that I bought the boat from Pheonix (1124 ft altitude) and now live in Calgary (3438 ft altitude). Can someone please provide me some guidance on how to re-jet this thing? First, where are the primary and secondary jets? Second, do both need to be replaced? Third, how can I tell what type fo jets I have now, and what type would you suggest I need?
dna is offline
Old 07-10-2015 | 09:21 PM
Looks like a weber/edelbrock. What model, 1410?
Mr Maine is offline
Old 07-10-2015 | 09:27 PM
You never said what the outcome of only 3900 rpm and 40 mph was, please update us.
GLENAMY 242SS is offline
Old 07-10-2015 | 09:29 PM
dna
Planning to update that thread after re-jetting. Though for a quick update I'm now at 4200rpm steady at 45 mph, after replacing my cap and rotor. Still not where I believe it should be. But been told that the jets are a big factor.
dna is offline
Old 07-10-2015 | 09:30 PM
dna
How can I tell - where would the model number normally be located?
dna is offline
Old 07-10-2015 | 09:35 PM
Call Jeff at Allstate Carburetor in Rochester, NY he will be able to get you the correct parts.
Old 07-10-2015 | 09:45 PM
Stamped on the front. Go one size lean all around. May not make a huge difference in performance but maybe fuel economy.
Mr Maine is offline
Old 07-10-2015 | 09:50 PM
dna
Looked again fgor any stamped numbers or names. No names, but have 9772S 1152 stamped on the bottom frame. Is that a stock merc carb? By 'all around' I assume you mean both primary and secondary? Where are they? When I remove them, how do I tell what they are (so I can call the local shop and tell them what I need)?
dna is offline
Old 07-11-2015 | 08:52 AM
https://www.google.com/url?sa=t&sour...29Y3xAjkiJ-o9w
Check out the link to the pdf of the carb manual for edelbrocks. I believe they are the same carb. The secondary jets will have a number on them. The primary will be a combination of jets and rods. Take a look at the jetting charts, you want to go one lean on both cruise and power mode.
Mr Maine is offline
Old 07-11-2015 | 12:27 PM
dna
From some googl'ing, I believe the stock merc carb that I have is made by Weber. I live in Calgary (a city with 1.1 million people), and not one shop sells jets and rods for Weber carbs. I tried the 4 marine dealers and every national brand auto parts store. I guess you need to live in a city with 2+ million to get stores to supply Weber parts. I think some of them say they do for Holley and Edelbrock. Can someone confirm if the jets and rods of these 3 makes are the same? Otherwise I'm gonna have to order it on-line and wait a week or two for one.
T
dna is offline
