Gaffrig gauges lens replacement >
Old 07-12-2015 | 12:23 AM
Default Gaffrig gauges lens replacement
Some of my lens cover are getting cloudy and hard to see through. Can you replace the glass only on them and not the whole gauge. If you can how do you take them apart with out breaking them?
Jj
conneroutlaw is offline
Old 07-12-2015 | 10:55 PM
I tried to have mine repaired, sent them back to livorsi and after they looked at them they said they could not fix them. The bezel has to be replaced when you replace the lens because it has to be cut off. They told me the new style bezel would not fit on the old style gauge. I bought all new gauges from autometer.
rumrunner29 is offline
Old 07-13-2015 | 05:57 AM
Thank you for the info, I am going to call them today and see what they tell me and ***** them out, The glass shouldn't go bad. It is all spider cracked and foggy and they should warranty the defect in the glass. Thank you for the insight, maybe I can get something out of them. If so it will be a late fall project right before it goes into storage, so I don't lay up the boat in our short season.
thanks
JJ
Old 07-13-2015 | 01:22 PM
Please keep us posted JJ. I've got a couple just like yours and it bothers me.
Hook'em is offline
Old 07-13-2015 | 04:08 PM
No problem, always glad to help. I had older gaffrig by livorsi monster gauges in my outlaw. Called them and they said they could fix them, but the rim on my gauges was no longer available. They said they could put the newer style on them and change all the lenses and pointers. After about 3 weeks I had heard nothing and called them. They told me that the new ring would not fit correctly on the older style, so they are not repairable. I don't know what gauges you have but I took it as that if you have older gaffrig gauges they cannot be fixed whatsoever. I went with autometer marine gauges because i didn't want to rewire the whole dash to go with the newer style connectors that livorsi gauges require. They turned out great, but I lost 2 months waiting on livorsi to look at my old ones and autometer to make the new ones..[ATTACH=CONFIG]543028[/ATTACH]
Old 07-14-2015 | 05:03 AM
I just sent them pictures of my dash and I will have to wait and see, They told me they were probably sealed and can not be taken apart, so I might have to buy new ones. I will have to see the price and how expensive it will be but I will keep you updated. I hope with these I don't have to retire the dash for them.
Jj
Old 07-21-2015 | 06:25 AM
It wont fix the cracking but wet sand and plastic polish will take out the cloudyness of those acrylic lenses and make them more bearable
airjunky is offline
Old 07-21-2015 | 11:00 AM
thanks for the info, I will try it
jj
Old 07-23-2015 | 09:35 AM
JBA
The bezel is easily removed by using a small straight blade screw driver and gently prying the rolled over edge on the back side of the bezel. I did this on my set and when put back together you would never know without looking extremely hard at them. I started on mine sanding and polishing like airjunky had said but still had to remove the lens and do both sides for the best result.
JBA is offline
Old 07-23-2015 | 01:14 PM
Thanks for the info on the gauges
jj
