496 iac plug
Old 07-12-2015 | 08:30 PM
Expensive Date's Avatar
Default 496 iac plug
http://www.amazon.com/Standard-Motor.../dp/B000C81PVI
Had IAC go bad and melted plug, got it out but its done. Is the link I posted the correct one?
Thank You
Expensive Date is offline
Old 07-12-2015 | 09:12 PM
BUP
Mercruiser has them for cheap to. and If I recall correctly - motorcraft WPT 357 might be the correct connector for the IAC.
I posted somewhere up here the connectors part # 's from mercruiser for most of the sensors. They are not expensive (no pun intended) expensive date.
BUP is offline
Old 07-12-2015 | 10:53 PM
BUP
Here read away and post 4 has your part number this is cheaper than what you posted FYI
link below.
http://www.offshoreonly.com/forums/g...then-stop.html
BUP is offline
