n/a piston to wall clearance.
does this seem normal. im building a 489 for my pachanga. started with a 330. now its going to be a forged 489 with 781 heads. anyhow. i bought some 14cc dome 2618 diamond pistons. they want the piston to bore clearance at .0055. with open cooling marine motors adding another.002-.004. this seems like alot to me but ive only ever built car motors. i understand the block staying cold and the piston material growing. but this motor will be lucky to make 475hp and will only be WOT for about 5 minutes total a weekend.
is .0055 ok or should i have the machinist open it up more. im dropping the pistons off this week for the final bore and i need to know what to tell him
thanks, Brandon.
thanks, Brandon.
thanks, Brandon.
thanks, Brandon.
Call diamond with the job number off your piston spec sheet. Discuss the build and intended use with them and they will be happy to confirm. I built 2 pro charged 383's using there pistons. Marine required .005, add .002 for open cooling add .002 for boost. Well that adds up to a sh!t ton for a 4.030 bore! I called talked to a tech and he said go .0065 -.007 so that's where we are.
Piston slap when its cold doesnt bother me. I called diamond and got some girl who said i would have to talk to the distributor i got them from. Ill try again tomorrow and be more persistent.
