Alignment of coupler w/ fixed motor mounts >
Old 07-14-2015 | 01:59 PM
Default Alignment of coupler w/ fixed motor mounts
Last year I had a coupler go bad on my 283 checkmate convincor. It did not spin the coupler but instead sheared the teeth on the aluminum sleeve may have hit a log and binded it when taking off not sure. Anyway boat is in great shape and has fixed motor mounts in front/back and alignment tool seems to go in as should. My question is does alignment ever really get off on a application like this and if so how do you go about fixing it. I just don't want to get stranded on the river any advice or thoughts would be appreciated.
jordan705 is offline
Old 07-14-2015 | 02:49 PM
The splines get bad from a lack of grease.
Alignment can change very slightly over time. It can be adjusted by redrilling the mounts.
Griff is offline
