502 carb 550hp - Blower vs NA >
Old 07-16-2015 | 12:48 PM
onesickpantera's Avatar
Default 502 carb 550hp - Blower vs NA
I know there have been plenty of "NA vs Blower" threads and I have searched them. But, I would like to hear opinions from the gearheads on here about this specifically.
If you had a 502 Mag (carb version) and you wanted 550hp, would you replace the cam, lifters, pushrods, rockers, springs, intake, carb and exhaust or look at putting a small blower (420 or similar) blower on top with upgraded head bolts/studs, head gaskets and valves?
Which is more cost effective and reliable at this moderate hp level?
onesickpantera is offline
Old 07-16-2015 | 09:00 PM
Rookie's Avatar
I don't think you could make 550HP with a 420 on a 502. Lol
Also, I believe 550HP NA vs Blown are 2 different power levels in a boat.
Rookie is offline
Old 07-16-2015 | 09:14 PM
502 at 550 with typicall bolt ons will likely be peaky and wet exhaust un friendly
502 at 550 with a roots will not , but it will cost you space front and top
airjunky is offline
Old 07-16-2015 | 10:10 PM
This kind of mirrors my thinking, decent cam, above average heads, what can a guy expect?
edit in ; I have zero room to get taller than the current stock setup.
buck35 is offline
Old 07-17-2015 | 11:27 AM
550 hp is obtainable with either, but I agree the delivery will be different. I was looking at getting there NA, and the costs add up quick. Which got me thinking, would it be cheaper and easier to pick up a used blower and go that route.
No right or wrong, just looking for opinions.
Old 07-17-2015 | 11:32 AM
If you can make it fit heck yea .
airjunky is offline
Old 07-17-2015 | 05:46 PM
i think what rookie is saying is if you go with a 420 blower you will be way over 550 hp.i am a blower guy but only you can decide what is best for you.the n/a build will not make the torque a blown deal will make but that will extend your drive,s life.what ever direction you choose to go you will need to upgrade to a good exhaust system,change cam&components,either replace the heads or at least have your heads worked,buy a carb or two,etc.if i wanted only 550 hp i would go n/a.
mike tkach is offline
Old 07-17-2015 | 06:08 PM
SB
The blower deal will probably make a little more EGT and thus be a little harder on your exhaust valve seats / valves, and etc.
Maybe better to change to a better (thicker head if cast iron) and new aftmkt head with attention to detail from a cyl head guy with thicker seat margins and etc.
Anyway, a cast iron RHS, Engine Quest, Dart head with with a mild cam will put you at that.
A stock head with '731 cam will put you just under that.
550 HP doesn't sound like much in todays world. But that's in comparison.
But, reality says it is still 550HP...which is, well, a lot.
SB is online now
Old 07-17-2015 | 06:10 PM
Rookie's Avatar
Yes, that is exactly what I was saying.
Rookie is offline
Old 07-17-2015 | 07:27 PM
Aaaaaand the next expense...what drive are you running?
Baja Rooster is offline
