Big Block Actual Dimensions >
Old 07-17-2015 | 08:53 PM
Default Big Block Actual Dimensions
Hi, I have a total 'newb' question regarding engine sizes; are the various sizes (454, 502, 496, etc.) just based on bore/stroke using the same block or are they actually different size engines completely? If, for instance, my boat had twin 454 mags, would I be able replace them with Mercury Racing 540s or maybe Procharged 502s?
I'm toying with the idea of a Scarab Panther and they usually seem to have 454s. If I wanted more power could I have them converted to 496 or 502, or are those different engines? Would they fit?
Again, I know it's pretty basic, but I just cannot seem to find an answer about this.
Thanks,
marko88 is offline
Old 07-18-2015 | 01:38 AM
454 and 502 blocks(Mark IV, GenV and GenVI) are different but can use the same cranks, rods, heads, etc.
The Merc 496/8.1(Gen 7) is totally different.
As far as mounting the external dimensions are all the same and any will mount in the same place.
Griff is offline
Old 07-18-2015 | 05:13 AM
Big x bigger
FIXX is offline
Old 07-18-2015 | 08:36 AM
Thank you
marko88 is offline
Old 07-18-2015 | 10:33 PM
So if I wanted, I could drop in twin MR 700sci's? Would air scoops be necessary for the blowers to breathe, I wonder?
marko88 is offline
Old 07-19-2015 | 07:34 AM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
What drive?
waybomb is offline
Old 07-19-2015 | 02:20 PM
Originally Posted by waybomb
what drive?
nxt1?
marko88 is offline
Old 07-19-2015 | 03:17 PM
waybomb's Avatar
That is good for the 700
waybomb is offline
Old 07-19-2015 | 05:47 PM
A tall deck.motor will be different dimensions. 9.8 deck vs 10.2 . That is what you need to watch out for. Exhaust will line up different etc
dsmawd350 is offline
