Is it NORMAL on step-hull's >
Old 09-12-2002 | 03:55 PM
blown formula's Avatar
Question Is it NORMAL on step-hull's
Is it normal on stepp hulls (Formula in particular) for the depth gauge to no read correctly when on plane? I assume this is due to the aeration induced by the step.....funny I should have realized that before I bought it......kind of dangerous to run where you have never gone before (on inland lakes) with no dependable depth gauge!!
Is there a fix? External transducer? true thru hull?
blown formula is offline
Old 09-12-2002 | 04:38 PM
Steamin Rice's Avatar
I have a new step bottom boat and my depth gauge only works at slow speeds.....I assumed it was normal?? I have a thru hull transducer
Steamin Rice is offline
Old 09-12-2002 | 04:46 PM
formulafastech....the transducer is glued to the inside hull starboard side of center rib about 2/3 the way back in the engine bay......there is a hole bored in the innerliner so as to make outer hull contact......glad yours works!!!
Steamin' rice- all Formula's have thru hulls, even my 97 312.......but I was questioning if the OLD stlye brass thru hulls or an external transducer would fix this problem??
Old 09-12-2002 | 04:55 PM
AAAhhhh I see what you are talking about. If you find out a way to get your depth gauge to work at all speed let me know..
Old 09-12-2002 | 04:58 PM
M2's Avatar
M2
Default '99 271
My transducer is located under the cabin step. It too has a hole bored in the inner liner so as to make outer hull contact. It seems to be accurate.
M2 is offline
Old 09-12-2002 | 07:19 PM
Tinkerer's Avatar
On a stepped hull the transducer has to be mounted in front of the step. For two step hull I would still think that it would have to be in front of the first step but that is a long way forward.
Tinkerer is offline
Old 09-12-2002 | 07:32 PM
Audiofn's Avatar
Charter Member #232
I am with Tinkerboat. I think that they have to be in front of the step.
Jon
Put your best foot forward!
Audiofn is offline
Old 09-13-2002 | 08:28 AM
Great, I see the logic for that. Unfortunately there is no posible way to get there!! That would be below the gas tank, and I'm not going to go thru that!! Any other solution?
Old 09-13-2002 | 11:55 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
You are going to have to get a transom/exterior mount transducer. I bought the Humminbird DF, which is re-labelled and sold as Gaffrig. It came with the transom mount unit and bracket. It is not that ugly. I do not have a stepped-hull, so I have the transducer mounted under my bilge pump plate. I know a lot of stepped-hulls have this problem.
Sydwayz is offline
Old 09-13-2002 | 12:25 PM
ApachePete's Avatar
Default 382
Mine is also under the cabin stair and works fine at all speeds.
ApachePete is offline
