Parker fuel valve solenoid replacement/substitute >
Old 07-20-2015 | 11:50 AM
Default Parker fuel valve solenoid replacement/substitute
I'm pretty sure these are necessary for both reasons USCG and fuel delivery system so I need 2 new ones? Is there another brand or do I have to go with the parker ones? If parker where can I get them I can only find them on eBay and they look like old stock that's been sitting on the shelf. Has anyone replaced them before? What did u get?
ivanfuego is offline
Old 07-20-2015 | 12:13 PM
Asco also makes very high quality solenoid valves.
Call up a Parker dealer in your area, I'm sure that valve is still in production so it's probably under a different part number. The dealer should be able to sort that out.
Here in OKC I use Precision Fitting and Gauge, very helpful.
Cole2534 is offline
Old 07-22-2015 | 10:48 AM
Thanks Cole, I'll just replace the same Parker ones. Asco seems to be the same or even more expensive.
