Anyone add hydraulic bleeder tees? >
Old 07-24-2015 | 10:41 AM
Default Anyone add hydraulic bleeder tees?
30 spectre with marine machine hydraulic steering, aeroquip 401-6B fittings on hoses; Had to change one out, thought I had it bled pretty good but steering is sloppy. Wondering if anyone has added bleeder tees to a system like this. I haven't seen any tees with 45 deg SAE (5/8-18) threads. I think someone mentioned that the marine machine cylinders have 1/4 NPT fittings---could probably find a bleeder T to fit that. Wondering if anyone has blazed this trail, could point me in the right direction to find the part. thx
bgrant_12002 is offline
Old 07-24-2015 | 11:10 AM
Never had an issue bleeding the steering to warrant a bleeder.
Black Baja is offline
Old 07-24-2015 | 12:12 PM
CIG3's Avatar
As long as you follow this procedure you should not need any other way to bleed.
http://www.everettperformance.com/PD...ING_SYSTEM.pdf
CIG3 is offline
Old 07-24-2015 | 12:18 PM
That's the correct procedure. If it doesn't bleed using this procedure there is a leak. A leak may or may not leak fluid...
Old 07-24-2015 | 12:45 PM
Thanks I'll give it a shot.
