New Quintessence43 from Midnight Express has Five Verado 400Rs >
Old 07-28-2015 | 04:10 AM
Jason Johnson's Avatar
Correspondent
Correspondent
Default New Quintessence43 from Midnight Express has Five Verado 400Rs
Named for its ground-breaking five Mercury Racing Verado 400R outboard engines uniquely set up with surfacing propellers and SportMaster drives, the latest model from Midnight Express Powerboats is called the Quintessence43.
http://speedonthewater.com/new-boats...e-verado-400rs
Jason Johnson is offline
Old 07-28-2015 | 06:07 AM
Payton's Avatar
Charter Member #927
Wow! I'd like to see a video of that running.
Payton is offline
Old 07-28-2015 | 08:58 AM
SPITFIRE's Avatar
Congrats. That is a beautiful boat and the new engineering is very impressive.
SPITFIRE is offline
Old 07-28-2015 | 03:02 PM
Cool but, (I woder which runs better) http://speedonthewater.com/new-boats...boat-and-watch
professor_speed is offline
Old 07-28-2015 | 04:50 PM
glassdave's Avatar
Neno the mind boggler
I am really just curious what does a five engine boat do that a four engine boat doesnt . . . . I mean if its just the "ghee whiz" factor i can understand that . But how does performance differ?
Friggin beautiful azz boat
08 OPA High Points Champion
glassdave is offline
Old 07-28-2015 | 05:00 PM
Its like an amp Dave... Sometimes your in a 4 engine boat and your running wide open and you need just a little bit more.. Like an amp that only goes to 10, what do you do when your playing at 10 and you need just a little more?? you get an amp that goes to 11 !!!!!!!
phragle is offline
Old 07-29-2015 | 09:27 AM
Tim has always liked things a certain way and this is a testament to that. Congratulations TC! It looks amazing!
powrbtr is offline
Old 07-29-2015 | 09:57 AM
The extra wide beam looks like it added a lot more space
altamate is offline
Old 07-29-2015 | 10:22 AM
jadento's Avatar
Lets see....on paper...
power - 4x557=2228hp, 5x400=2000hp advantage 557 by 228hp
weight - 4x1100(approx weight each)= 4400lbs., 5x668(from mercs site dry)= 3340lbs. advantage 400
then you have 4 lower units in the water vs. 5 = drag advantage 557.
but having 5 props in the water vs. 4 could give could give the 400 boat efficiency advantage?
Heres a different angle...
4 x $69Kish retail = $276K vs. 5x$34K(average retail) = $170K major advantage 400! Not that anyone that can afford these boats cares about the cost.
My guess....who cares there both bada$$ and ill never be able to afford one.
***Disclaimer - I make no claim to the complete accuracy of the specs as I have not purchased, weighed, dyno or even seen either motor ; ) Ok Ive seen a 400. I searched them on google!
jadento is offline
Old 07-29-2015 | 11:18 AM
Marina I used to frequent had a beautiful 39 Midnight with quad 275's......boat was always there for repair. The two outside motors ate gearcases like crazy when the boat was under hard acceleration and turning one unit would basically go dry! That was 4 engines driving the mechanics crazy, 5 would really send them over the edge!
I'd stick with triples.......going uber fast in a CC isn't really that fun anyway!
Jupiter Sunsation is offline
