Need a measurement from bravo stub shaft tool >
Old 07-28-2015 | 11:34 AM
Default Need a measurement from bravo stub shaft tool
I am setting up the gear lash on my bravo, but I don't have the stub shaft tool that holds the gears and it is over a week to get one....and it's 3 weeks before any shop could do it.
I can set up the lash using the yoke instead, but I need to know the diameter of the stub shaft tool where the gear lash flag sits. If I have that measurement, I can calculate what my lash should be when using the yoke instead of the tool.
Also...anyone have a alternative for merc 1x u-joints?
Hope someone can help.
Thanks in advance.
yeller is offline
Old 07-28-2015 | 02:07 PM
I have the tool, call it 3/4 inch, actually .752, where the flag clamps on
hope this helps
253 is offline
Old 07-28-2015 | 02:17 PM
Excellent! Thanks.
I forgot to specify this is for a Bravo 1x. I know there are different tools for the b1 and b1x. Which one do you have?
yeller is offline
Old 07-28-2015 | 10:10 PM
Mine is for the Bravo1 pinion gear w/ the smaller hole, , that may be the only difference
253 is offline
Old 07-28-2015 | 11:10 PM
Yes, I assume they are the same. Did the calculatinos and even if the 1x tool is different by 1/4", I'll still be within specs.
Very much appreciate your help!
yeller is offline
