Very stiff steering >
Very stiff steering
Very stiff steering
Old 07-31-2015 | 03:22 AM
Default Very stiff steering
Have Marine Machine full hydraulic steering on 37' 500efi's. Very stiff at all times basically like no power assist. Pump is full and fluid doesn't smell burned. Any ideas on where to start looking? It's a pretty workout turning the wheel.
Faster Daddy is offline
Old 07-31-2015 | 12:21 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Is it easier at higher RPMs?
Sydwayz is offline
Old 07-31-2015 | 01:58 PM
No sir it's the same at all times
Old 07-31-2015 | 02:03 PM
Someone said possibly the ram or rams could need a rebuild? Another said the pumps on these 500's and 525's don't produce enough pressure and needs a hole drilled somewhere?lol
Old 07-31-2015 | 03:15 PM
ActiveThunder's Avatar
Open the cap and see if fluid is flowing. Whoever told you to drill a hole somewhere, disregard that idea.
ActiveThunder is offline
Old 07-31-2015 | 04:14 PM
Lol I kinda threw the drilling out the window already!! Alright I'll fj the fluid sir for circulating sir. Thank you!!
Old 08-02-2015 | 09:37 AM
Replace the pump.
michigan troll is offline
Old 08-31-2015 | 12:17 AM
Ok guys replaced the pump and still too hard to turn. Did help it a little, but very little.. Any other ideas or suggestions would be much appreciated. Going to check the filter tomorrow, but idk if that could/would caus this?? Always the same stiffness regardless of RPM's.
Old 08-31-2015 | 12:25 AM
Was just doing some searching and read about what fluid to use. Is it possible the "power steering fluid" is too light for the system and I should put "ATF fluid" in it instead??
Old 08-31-2015 | 06:41 AM
My Zeiger system does call for ATF but I doubt that's your problem. If you haven't checked the filter yet, that could be your problem. Just see if you can blow through it.
thirdchildhood is offline
