572 Blower Motor Knock Sensor / Misfire Problem >
Old 08-05-2015 | 09:41 AM
Default 572 Blower Motor Knock Sensor / Misfire Problem
Looking to get some positive suggestions / help with this problem. Here's the deal....
I am getting a knock sensor / misfire on my port engine only:
1>Usually only happens when engine is warm, under load, and between 2000-3500 RPM
2>When engine is idling, it almost sounds like there is a spark jumping around somewhere but unable to locate.
3>I am running 10-20% 110 octane mixed with 93.
4>The motors are low 8:0-1 and 5-6psi boost.
Any ideas, help, or suggestions would be thankful.
dmaxximus is offline
Old 08-05-2015 | 03:13 PM
GPM
What ignition box are you running, any chance it could be rotor phasing.
GPM is offline
Old 08-05-2015 | 04:33 PM
Are you sure its not actually knocking? Warm engine, low engine speed, heavy apache, possibly too much timing there? I dont see the need for race gas if its 8:1 with only 5-6lbs of boost. We been running that on 93 octane forever..with even more boost.
MILD THUNDER is offline
Old 08-05-2015 | 05:44 PM
i would replace plugs,wires,cap&rotor.carbon tracking in the cap or spark jumping from one wire to another.
mike tkach is offline
Old 08-05-2015 | 05:49 PM
F-2 Speedy's Avatar
^^^^ agree cracked cap ? maybe a wire boot arcing to the head, fire it up in the dark, if its an arc easy to see.
F-2 Speedy is offline
Old 08-05-2015 | 06:00 PM
These are EFI engines? Or Carb? What ignition setup?
Old 08-06-2015 | 08:52 AM
I actually think it's a backfire, makes a snap/pop noise when it does it but the knock sensor goes off.
Accel DFI
Accel Rotor / Cap
Phillips Racing Spiral Wires
MSD Ignition 6M-2
Crane Cams Fireball LX91
Old 08-06-2015 | 09:34 AM
Cap rotor and wires a good start. Sounds like it may have a lean spot in the curve too if its popping back thru the engine..
Old 08-07-2015 | 06:46 AM
GPM
Are you running the dual sync distributor
GPM is offline
Old 08-07-2015 | 06:51 AM
Accel DFI
Accel Rotor / Cap
MSD Ignition 6M-2
I'd check the valve lash again.
sutphen 30 is offline
