540 ci bb chevy blower timing
I recommend either a daytona sensors, or MSD programmable ignition system. Every engine is different as far as what it may like, or not like for timing. Too much is not good, and too little is not good. Many look at timing as a "power adder" or "power reducer", but that is simply not the way to setup a marine engine, especially a supercharged one. The goal is fire the plug at the right time, for best combustion event. Firing to early even without preigntion, still doesnt always mean the best power. Fire the plug when the piston is still too far down in the bore, creates negative work, or force against the piston trying to come up. Firing to late, simply wastes power, and can make EGT's skyrocket. There are many factors, and this is where dyno tuning is invaluable.
What are the details on the build? Small blower? how small? What heads? What cam? What compression? Intercoolers?
I totally agree wild Mild Thunder...with that much cam you will need to run some good boost to take advantage of that cam. With that small a blower with the cubic inches you run & with an inner cooler that will lower overall boost, you are not going to get much boost. Sell that blower and get a bigger one ie. 8 or 10-71, you will be way better in the end, with alot less problems.
