Twin aluminum Small Blocks good idea, or a bad idea? >
Old 08-10-2015 | 11:14 AM
Default Twin aluminum Small Blocks good idea, or a bad idea?
Guys, look for some feed back..
Was thinking about building a pair of small blocks for a 2004 32ft fountain . It currently has 300 hp mpi small block set up.
Was thinking to start with a Dart Aluminum block and Pro1 aluminum heads to chop some weight
It would be 400 CID.. full roller motor with forged bottom end. looking for 450 - 470 hp
Any one have any comments on Aluminum small blocks for Marine applications?
Was thinking to go closed cooling? is this a must for an aluminum block?
Boating in freshwater only for this boat.
Regards,
Unreal Offshore.
unreal offshore is offline
Old 08-10-2015 | 11:28 AM
I think you are in uncharted territory!
thirdchildhood is offline
Old 08-10-2015 | 11:47 AM
I have always thought the new AL LS motors would be killer in a 32.
Get weight off the back.
Wildman_grafix is offline
Old 08-10-2015 | 11:51 AM
SB
Aluminum SBC blocks are not cheap. Would probably be same money to use current LS architecture with a bunch more power.
SB is offline
Old 08-10-2015 | 11:53 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Yep, I'd do with LSX power.
Sydwayz is offline
Old 08-10-2015 | 12:02 PM
The reason why i am trying to keep the weight off. is 1) yes speed !!!!!! but my other consideration is towing it when on the trailer.
Old 08-10-2015 | 12:04 PM
How much power can you put into a small block and keep it reliable?
Old 08-10-2015 | 12:12 PM
My buddy put two LS3's in a 30' Profile V bottom. They are all aluminum. Boat runs 95mph all day every day. Pump gas re-jetted hp 500 carbs. He used closed cooling systems off 454's.
Black Baja is offline
Old 08-10-2015 | 07:44 PM
Nice.. That LS3 is an amazing engine..
Old 08-10-2015 | 07:52 PM
thiers a guy on here that tyler crocket did some nascar small blocks in a boat for him and it kicked ass
innerrage is offline
