Rear port engine mount bolt loose
89 454 Bravo1
I noticed the other day that the port side rear mount bolt was loose, I tried to tighten it but it just spins. Does the nut get pulled inside the mount, I don't feel it on the bottom?
Pic
http://www.marineengine.com/newparts...MER10-97934A+1
Thanks for any help,
Pic
As TA said, its in a slot on the transom plate, so its higher up than the end. Part #12 is the nut in this link. As you can see, it slips into a slot on the plate and that holds it in place when you pull the bolt out. Its a fine thread bolt, so it takes a while to tighten, but as mentioned, its aluminum, so they can strip out. But you should be able to follow the bolt up to the plate, and then up to the slot where the nut goes, and you should be able to feel it there.
http://www.marineengine.com/parts/me...nd-shift-cable
