URGENT.....HELP/Advice Needed on 2003 Fountain 38TE!!! >
Old 08-11-2015 | 07:23 PM
Default URGENT.....HELP/Advice Needed on 2003 Fountain 38TE!!!
Hi Everyone, I'm new to the forum and need some advice on a 2003 Fountain 38 Tournement Edition center console boat. I have an offer in and it is under contract pending an official inspection and survey. I'm still looking around for a certified guy to do the survey so if someone could recommend a good one located around Lake St. Clair, MI (St. Clair Shores, MI) it would be greatly appreciated.
Now onto my concerns....I noticed that the rear scuppers that go through the transom are stainless steel and one of them is missing the rubber grommets on both sides. I've heard/seen horror stories on this forum about this particular boat and how water can leak in and rot the transom especially around the scuppers. So my questions are:
1. How do I check to see if water has leaked into the transom and has started to rot? Would the person doing the survey be able to do this or is there something I could do myself while I wait?
2. What should I look out for on this particular boat specifically and are there any "gotcha's" I should be concerned about?
3. If the transom would need to be replaced approx. how much would it cost on this particular boat? Any locals that could quote me?
Quick notes on whats noticeably damaged:
- Center engine fiberglass cover is dented in on the corner.
- Steering wheel is loose (it wiggles and it's not related to the tilt)
- Air Conditioning unit is broken
- Might need a new pump (not sure yet)
- Cushions are sun faded
- T-Top is sun faded
- It is used in FL for the winter months and then brought up to MI for the summer months
- One cup holder is busted
- There is paint chipping around the engine levers
- The gauges are sun faded
- Rear engine transom mount braket is all chipped and faded
- Transom scuppers are missing rubber grommets
Boat Info and facts:
38' Fountain 38 Tournament Edition
Year: 2003
Located in St.Clair Shores, MI
Dimensions
Beam: 10 ft 6 in
Minimum Draft: 2 ft 0 in
Maximum Draft: 2 ft 5 in
Bridge Clearance: 8 ft 0 in
Dry Weight: 10600 lbs
Engines
Total Power: 675 HP
Engine 1:
Engine Brand: Mercury
Engine Model: Optimax
Engine Type: Outboard 2S
Engine/Fuel Type: Gas/Petrol
Engine Hours: 478
Engine Power: 225 HP
Engine 2:
Engine Hours: 478
Engine 3:
Engine Hours: 478
Tanks
Fresh Water Tanks: (30 Gallons)
Fuel Tanks: (287 Gallons)
Accommodations
Number of single berths: 2
Number of heads: 1
Electronics
Depthsounder
GPS
Cockpit speakers
VHF
Compass
Radar
Inside Equipment
Electric head
Battery charger
Electrical Equipment
Shore power inlet
Outside Equipment/Extras
Cockpit shower
Swimming ladder
Additional Equipment
Launching trailer
Deck
Anchor locker
Cleats, pop-up bow w/amidships and stern
Fish boxes, 4 under floor w/macerator & overboard drain
Rod holders
Sink w/pressurized water system
Livewell at transom, 50 gallons
Rod/gaff storage (4 under gunwale, 8 under v-berth)
Salt water wash down
Elecrtronics & Helm Console
Console cup holders
Helm seat, leaning post style w/ fixed backrest & rod holders
Trim tabs
Fuel gauge
Mercury Smartcraft gauges
Steering, hydraulic, w/tilt steering wheel
Compass
Tactronics display plotter
Kaffer controls
Electrical
Batteries
Bilge pumps
Battery switches
Cuddy Cabin
V shape seating with filler cushion to make a berth
Rod storage
Radio
Flourescent lighting
Walk-in head w/VacuFlush, shower, sink, and 25 quart cooler under forward-facing seat
Air Condition Unit (Broken)
Photos to the boat in question can be found at the link below:
https://drive.google.com/folderview?...jQ&usp=sharing
Cheers,
Chris
chris_dobz is offline
Old 08-11-2015 | 08:05 PM
Nykamp's Avatar
Use Dennis Biel for your survey he's in Detroit , great guy!! 1-586-219-7219
Nykamp is offline
Old 08-11-2015 | 08:11 PM
Omg, hilarious...I literally just booked him for the survey this Monday morning. Too funny. Plus I've heard that he is the best from multiple sources so thank you for confirmation. I'll be sure to update the thread with the results.
Cheers,
Chris
Old 08-11-2015 | 09:31 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Pull the stainless scupper out of the transom completely.
Take a small screwdriver and poke at the wood to see if it's soft.
Your surveyer should have a moisture meter. Sound investment if so.
Sydwayz is offline
Old 08-11-2015 | 09:49 PM
Thank you!!! Much appreciated!!!
Cheers,
Chris
Old 08-12-2015 | 05:26 PM
Did you really just post OMG on one of the manliest forums on gods earth... Ever participate in a gay pride parade? Not that there's anything wrong with that
iliveonanisland is offline
Old 08-12-2015 | 05:48 PM
Nah, I'm straight money yun! Definitely should not be responding to your troll, however, I need a slip in Miami Beach if any of your gay pride friends know of any available?
Old 08-12-2015 | 08:43 PM
I didn't realize those are so wide
hogie roll is offline
Old 08-12-2015 | 09:09 PM
I would have a motor survey too, 2003 was the first year they had figured the Optimax out, prior to that they were pretty unpredictable and nicknamed Optibomb. The air compressor is the weak link, a survey can tell you if they have the newer style or if the bearings are starting to wear.
Good Luck, I have heard the 38TE is one of the best riding CC's ever
Pete280 is offline
Old 08-12-2015 | 09:13 PM
Thank you! Do you know when Fountain switched to marine grade plywood in the transom and more specifically the material used in the transom on this rig?
Thanks,
Chris
