2008 Lightning Gas guage not tracking levels correctly >
Old 08-12-2015 | 09:46 AM
Exclamation 2008 Lightning Gas guage not tracking levels correctly
All,
I just purchased a 2008 Fountain Lightning with 525's. 90 gallon tanks x 2. Livorsi gauges (analog) and Smartcraft.(digital). The Smartcraft readings are all digital and dead on. Unfortunately I don't see a gas reading on Smartcraft, so my guess is the 2008 factory installed Smartcraft does not have a gas sensor or did not have that capability in 2008?
so onto the Livorsi gas gauge... What happens is when you fill up 100%, the gas gauges go to past full and will stay at 100% for a really long time (weeks possibly based on how much I run) until the tanks are maybe 50 to 40 % (actual gas in tank) then all the sudden drops to 50% on the gauge or 25%-30% on the other). It does not show at all the progress from 100 to 90 to 75 to 70 % for example. Its either 100% or 50/40%. This is problematic if I am making a long run in a day and not close to a marina. Since the boat is brand new to me, I'm not sure what the behavior is from 40-50% actual to no gas at all in the tanks. I did notice that once it dropped, my starboard gauge read 50% and my port more like 25-30%. I am pretty sure that when they dropped, they dropped at the same time from 100% to either 50% or 25-30% depending on the side
How can I tell how much gas I actually have in the tanks? Could a module be added to the smartcraft or would that actually mean I would have to get a digital sensor somehow into the tank itself? (hmmm) Could it be a Livorsi gauge? (Im thinking not since both gauges do the same thing). Could it be a ground issue? Or is it most likely that the sensor in the tank is just a really inaccurate one by design?
Any insight is greatly appreciated
MJBoater is offline
Old 08-12-2015 | 11:19 AM
I would do a search on the Fountain Forum and you will get tons of examples of this. BUT my rule of thumb (learned the hard way)!!!
Fill it up! Now you know its full!!!
When it starts to move a little and "bounce" but stay close to full you have 3/4 tank. When it comes off of full you have 1/2 a tank or less. (start thinking about a fuel stop). When you are reading between 3/4 and 1/2 Stop thinking about filling up and GO fill up. When it gets to 1/2 or below your lucky if the engines are still running. This is just a rule of thumb that has helped me. I ran out at Lanier poker run and fried a starter thinking it had fuel. Lucky I didn't burn a fuel pump. Spent the rest of the day limping along on one engine. Ran it out of gas 100 yards from fuel dock. Now I fill up before every poker run to be sure. If I'm hanging at my local lakes I can go several times on a tank and not worry about it. BUT I ALWAYS KEEP IT IN MIND!!!
682gold is offline
Old 08-12-2015 | 11:29 AM
You are experiencing what every other Fountain owner has already with the gas tanks. The senders are located at the rear of the tanks, so with the boat in the water leaning backwards, those senders almost always read full until you really get much closer to empty. I've put brand new gauges and new senders in my boat and they still behave the exact same way, its not that equipment. Its just the design of the boat. My way of solving this has been to fill up, run the boat, watch how many hours you run and then refill again and check your hourly consumption. Then you can approximate how much gas you're burning on average per running hour and you can mentally adjust if you are wide open for longer periods of time. I have 105 gallon tanks. My experience has been that the gauges stay full until you're half full and then they start moving lower. when I'm between 1/2 and 3/4, thats usually an indicator that I have about 1/4 tank. Last time I dipped down to below 1/2, I had 17 gallons left in the tank.
HyFive578 is offline
Old 08-12-2015 | 12:41 PM
Mine seem to behave the same way. However, they are reasonably accurate when the boat is on the trailer
RT930turbo is offline
Old 08-12-2015 | 02:13 PM
MJBoater My 38 EC does the same thing. I would suggest the fuel sender unit mounted on the fuel tank needs to be calibrated with the fuel gauge. If you talk with Livorsi or research the sender, it is designed to work with different depth fuel tanks. There are calibration screws in the top of the sender unit that is bolted to the top of the fuel tank. There are two screws to adjust, one for full and one for empty. You are supposed to fill the tank to full, then adjust the screw until the gauge reads just at the full line, not past. Then run the tanks low or dry and adjust the other screw the gauge reads exactly at the empty line. This sets the range of the gauge to match the depth of the fuel in the tank. My thought is that the Fountain Factory never fills these tanks to full, so they can never adjust the fuel sender unit as livorsi requires. I know this as I installed the same gauge and sender on a 357 Formula, cut the sending unit to my tank and adjusted accordingly. Worked perfect. I think once you do this adjustment, the gauge will show the progressive drop of gasoline in the tank. I will be doing mine soon and will let all know if it works.
38fountainecman is offline
I was wanting to run a WOT test and see my top speed..(since I wont have a ton of extra gas weight) .. its about a 20 mile run down and back. But I'm guessing at this point, I may run out of gas?
MJBoater is offline
Old 08-12-2015 | 02:57 PM
There is a Smartcraft gas reading. In the display where you can choose charts, chart gauges, etc, there is another level to set up your gas tanks. It will allow you to set an alarm when it gets to your desired level. The only problem with mine, is you have to fill it up every time and reset it. If you go put 60 gallons in or whatever and it's not full, it doesn't function. It will also give you all the full consumption figures. Google your model if you don't have the owners manual. Hope this helps.
Feverz29 is offline
Old 08-12-2015 | 05:20 PM
I replaced all of my fuel senders with Livorsi AutoCal senders that do not require calbration. Still behaves exactly as I described above.
Old 08-12-2015 | 06:23 PM
I think the big issue is the physical level at the sender never changes until the tank is half empty. Given the shape of the tank, and the angle of the boat, the entire sender is always "Wet" Make sense?
Old 08-12-2015 | 06:39 PM
Different boat but mine read a bit better when on plain, the boat is more lever.
Wildman_grafix is offline
