my brothers 525 sc . get to 3500 and just spit and spatter >
Old 08-12-2015 | 12:03 PM
ROB FREEMAN's Avatar
Default my brothers 525 sc . get to 3500 and just spit and spatter
any thoughts ..ive got him to this thread lets see if we can help him out .. i think fuel delivery myself .. thanks guys
ROB FREEMAN is offline
Old 08-12-2015 | 12:32 PM
Coil
Black Baja is offline
Old 08-12-2015 | 03:03 PM
They are fairly simple engines. Start with the basic ignition tuneup and go from there.
Griff is offline
Old 08-12-2015 | 04:49 PM
Coil, or coil wire. The coil wire works 8 times as hard as the rest of them. Its all a guess from here
MILD THUNDER is offline
Old 08-12-2015 | 04:59 PM
thanks and darn it , when you putting them blowers on . )))
Old 08-12-2015 | 05:29 PM
We need to talk about that !
Old 08-13-2015 | 07:56 AM
whats the fuel pressure when starts going away ?
ezstriper is offline
Old 08-13-2015 | 08:18 AM
I had the same problem. Fuel pump was going bad Ethanol ate it up. Ran fine at idle and up but when secondary's opened up it would cough and die. Pump pressure went to 2 on the gauge from 7
Car Biz is offline
Old 08-13-2015 | 05:51 PM
yes we do ...
Old 08-14-2015 | 06:14 AM
had a friend with same engine, the water pump leaked the fluid out, wore the are down bad on fuel pump, would only make about 2500, but you could see fuel pressure go away...expensive pump by the way...I hate mercs pump setup...
