AN fuel line question. >
Old 08-12-2015 | 11:27 PM
Default AN fuel line question.
Going to be cleaning up some of my rigging this winter and will be making the switch to AN fittings and braided lines. What size AN line do I need to feed a mild 350 with a 650 cfm carb?
87MagnumII is offline
Old 08-13-2015 | 01:36 AM
I would use #8(7/16) but you'd probably be fine with #6(5/16).
Griff is offline
Old 08-13-2015 | 07:53 AM
#6 is fine
ezstriper is offline
Old 08-13-2015 | 08:38 AM
Just a note for you AN and braided lines are NOT coast guard approved. I know it sounds stupid but I did the same as you and put nice AN braided hoses and surveyor and insurance say nope : ( You can have the lines on the carb and lines mounted on engine, but after that its silly double hose clamps and rubber USCG approved hose lol.
64294501 is offline
Old 08-13-2015 | 10:41 AM
articfriends's Avatar
I too used an hose on.my Baja, coast guard never said a word when they inspected it although its illegal technically
articfriends is offline
Old 08-13-2015 | 10:47 AM
I believe there's a push-on hose available that's USCG approved when properly clamped. Orlandi posted the part numbers once.
Cole2534 is offline
Old 08-13-2015 | 11:14 AM
F-2 Speedy's Avatar
push lock hose to AN fitting .........I think most if not all braided is a compression type fitting
F-2 Speedy is offline
Old 08-13-2015 | 09:18 PM
If you do go with braided stainless hose, use the Teflon lined hose. It holds up better to fuel than he rubber lined hose. Also the ID of the teflon lined hose is a bit larger than he rubber lined ss hose
mwicard is offline
Old 08-13-2015 | 09:24 PM
Doesn't have to be clamped but it must have the yellow washer on the hose end.
Black Baja is offline
Old 08-13-2015 | 09:26 PM
Best thing is when they ask you if the blowers work and you turn them on to show that they work and they do. But there is no hose on the blowers. Just mounted to the transom and wired.
