gil tail pipe question >
Old 08-13-2015 | 07:26 AM
Default gil tail pipe question
Bought a used set of tailpipes they have a 3/8 male fitting on the bottom for a small hose? where would that go? or can it be pluged?
actionmarineguy is offline
Old 08-13-2015 | 07:40 AM
it returns to the back side of manifold
smokin' gun is offline
Old 08-13-2015 | 09:23 AM
Thanks, But more questions? To the top of manifold or bottom where drain plug is? What is its purpose? Had many boats without this?
Old 08-13-2015 | 09:50 AM
I was told it was to reduce stem pockets in the tails. There should two 3/8 nipples on the back side joined with rubber hose.
Donzi1979 is offline
Old 08-13-2015 | 01:09 PM
It connects to a fitting on the exhaust manifold with about a 4-6" piece of hose I don't think all the Gil manifolds had the other fitting though.
You can just cap/plug it if you don't have the matching fitting on your manifolds.
Griff is offline
Old 08-13-2015 | 03:49 PM
Thanks for all the advice.
