need help!!!!
Somebody please help me figure this out.I have a 28 warlock sxt cat,and it blow the prop out realy bad.it has a 30 bravo on it nowbut also I tried 29 hydromotiv and the boat wont even plane at all.It has an 12 inch extension imco extension box on the boat...Peopl tell me the drive is too high,I put a straight line from the bottom f the boat straight out from the drive with drive trimmed all the way down and Im 3 inches higher than the boat with the prop..This doesent soulnd right oo me.Please help!!!
I agree with Offshore Addiction. You need to bring that x dimension down. Any will help but it sounds like you need three inches to get to the keel line. If you are moderately powered you probably should be even below that. Does your boat have a notch on the transom just in front of the drive on the center sponson? If so you need to measure from the height of the bottom of the boat not the notch.
I have a ChrisCat drives are about 1/2 in up try some larger diaminter props if you can find some. At 3in up I bet you have a hell of a time getting on plane. Take off slow ease in to the gas to get a little speed then when the prop brakes loose take it up to about 6k for a few seconds then back out of the gas to around 3k or so and see if it bites and takes off it that doesent work stand on the gas untill it takes off.
