on / off hull cleaner?
Old 08-14-2015 | 07:51 PM
26sonic's Avatar
Default on / off hull cleaner?
does anyone know the best prices on this stuff or anything else out there that is just as good or better ?
26sonic is offline
Old 08-14-2015 | 08:08 PM
The least expensive toilet bowl cleaner will clean it beyond belief. I also I use "iron out" to get out the yellow stains.
All the best
3pointstar
3pointstar is offline
Old 08-14-2015 | 08:20 PM
Just be careful it melted my carpet on my trailer but it cleaned the hull great.
boomer is offline
Old 08-14-2015 | 09:31 PM
The Works toilet bowl cleaner works great.
Rattlesnake Jake is offline
Old 08-14-2015 | 09:51 PM
Slimy Grimy works good too. Its a powder you mix with water. Spray on, brush and rinse.... not much elbow grease needed at all.
Got Cigs is offline
Old 08-14-2015 | 09:57 PM
The Works or Sno Bowl toilet bowl cleaner. Use a pump garden sprayer to make it easy. Both are acid based so rinse very well.
Griff is offline
Old 08-14-2015 | 10:33 PM
seafordguy's Avatar
On-off works great, but I use slimy grimey because it comes in a spray bottle and i can just shoot it on the hull while it's on the lift
seafordguy is offline
Old 08-15-2015 | 07:18 AM
FSR cleaner works great , can order online or pick up at west marine
riverboater is offline
Old 08-15-2015 | 09:09 AM
Is there any danger of discoloring getting any of these on a black gel coated bottom part of hull (when using it on white deck) ?
stealth1 is offline
Old 08-15-2015 | 09:55 AM
Do a search for Ring-go on here....by far the best and easiest product I have ever used.
TCBoss302 is offline
