Looking for a mpi version 5 and 6 ECM >
Old 08-18-2015 | 12:35 PM
Hey guy thank you for letting join this forum
Ok here is a hard one
I need two ECM,s for the older MPI engines
MERCRUISER : 7.4LX BRAVO (MPI)(GEN. VI) GM 454 V-8 1996 - Serial number K151719
ECM number 860251T 1 .............cool fuel system
MERCRUISER : 7.4LX BRAVO (MPI)(GEN. V) GM 454 V-8 1995/6 - Serial F602510
ECM number 807210T 4 ............vapor tank system
Seems both of mine are partly dead they where running until the engines where removed and rebuilt and now the injector pulse has stopped working
Gone over every wire and tested everything
Fuel pumps work, spark works
Turn on the key and turn the dizzy by hand can hear the pump start up but there still seems to be not injected driver going to ground,
Checked every ground wire and power wires everything is right,
I can only put it down to the Crain that installed my engines was a old heap with a cable and used a chain on both engines it might have got a dose of static charge from the drum roll of cable,
Any help or info would be great thanks.
gazzzza is offline
Old 08-20-2015 | 07:35 AM
Default Can someone recommend where I can send theses units to be tested ?
Hey guys if no one has anything lying around can some one recommend somewhere I can send theses to be tested ?
Thank you
gazzzza is offline
Old 08-23-2015 | 03:18 PM
www.mefituning.com
tunertech is offline
Old 08-27-2015 | 03:02 PM
I have a ecm and a vst./ ecm pn# is ill guarantee it works or double money back. kevin 413-246-2152 model # 16234539 96 mag mpi w/ cool fuel and vst.
sn ( bar code # ) 464539ka00004454. cvall me if you want it 250 delivered.
nordic572 is offline
