What plugs to use on a aluminum head ? >
Old 08-20-2015 | 09:46 AM
Default What plugs to use on a aluminum head ?
I recently did the top ends and changed the heads. I put the ngk bpr6es in it . Just wondering what anyone else is using.
excalibur82 is offline
Old 08-20-2015 | 10:13 AM
F-2 Speedy's Avatar
NGK-V power R5671A-7
F-2 Speedy is offline
Old 08-20-2015 | 10:37 AM
What heads are we talking about?
fbc25el is offline
Old 08-20-2015 | 11:16 AM
I put the promaxx aluminum on it
Old 08-20-2015 | 05:27 PM
As long as the heads call for a 3/4 reach 14mm plug the NGK R5671A-7 would work. NGK plugs the lower the number the hotter the plug.
fbc25el is offline
Old 08-21-2015 | 08:01 AM
MrCIG's Avatar
Charter Member#330
Put a dab of anti seize on the threads
MrCIG is offline
Old 08-21-2015 | 09:52 AM
same as recommended, just use anti-seize like MrCig said.
BBCLiberator is offline
Old 08-21-2015 | 06:26 PM
using same plugs but with a bit of anti-sieze on the threads.
HyFive578 is offline
