CMI Header hot spot
Old 08-23-2015 | 12:27 PM
Default CMI Header hot spot
[IMG][/IMG]
What would cause this,a leak? I did have a belt fail (delaminate) it slipped, on the raw water pump.
MichiMike is offline
Old 08-23-2015 | 12:54 PM
Originally Posted by MichiMike
[IMG][/IMG]
Poor water flow. Mine did the same on my 250/540's with a crossover. Removed the T-stat for now and it is better
jamontes is offline
Old 08-23-2015 | 01:22 PM
Thanks I will try thermostat trick.
Old 08-23-2015 | 03:35 PM
1 MAIDEN AMERICA's Avatar
Pull the hose and look inside the header. The passages can get restricted with junk. Use a coat hanger to pick it out/through
1 MAIDEN AMERICA is offline
Old 08-23-2015 | 07:37 PM
BUP
do you have sea strainer like above said junk or a restriction or not enough volume of water / flow
BUP is offline
Old 08-23-2015 | 07:41 PM
just worked on exact same issue, oil cooler partially clogged
ezstriper is offline
Old 08-23-2015 | 08:27 PM
Tinkerer's Avatar
You should pull the inlet end off of your oil cooler at least once a year and run a rounded end brazing rod through each tube to clear any blockage. I have seen where half of the tubes were blocked.
Tinkerer is offline
Old 08-24-2015 | 01:52 AM
Lack of water flow for sure. Check the Tstat housing where the check balls are for a restriction. That is what feeds water to that hose.
Also, keep in mind, those stock Merc hoses with the steel braid get bad internally even when the look good.
Griff is offline
Old 08-24-2015 | 03:51 PM
Well It has a brand new oil cooler..New circ pump,new sea/fuel pump,new t-stat.raw water no strainer
My new sea/fuel pump may be suspect due to the fact I reused the old gaskets and body(2 piece) with a new impeller.
Water temp gauge never went above155. am going to check these suggestions along with the replacement of pump impeller and housing.
Old 08-29-2015 | 03:22 PM
Pulled the sea pumps on both engines impeller housings worn out.Should of replaced them before.
New ones now should be good to go.
