supercharger or n/a for reliable performance increase >
Old 09-08-2015 | 07:44 PM
Default supercharger or n/a for reliable performance increase
just curious which way is least complicated and most reliable., a low boost supercharger or heads, cam etc? will either be effective without thru hull exhausts?
stimleck is offline
Old 09-08-2015 | 07:48 PM
The day after labor day and you want to start this winter chit already???
I realize your fromm the great white north but christ man, at least wait for the leaves to start changing!!
phragle is offline
Old 09-09-2015 | 02:53 PM
without doing exhaust you are pissing in the wind
ezstriper is offline
Old 09-09-2015 | 03:46 PM
I believe that exhaust scavenging is not as important with forced induction as it is with normally aspirated, but I don't think you can get away with forcing that volume of exhaust through an opening that is approximately 2x3 inches. It's a bit like John Holmes trying to fornicate with a chihuahua.
Budman II is offline
Old 09-09-2015 | 04:42 PM
SB
Speaking of John Holmes, while being relevant to the opening post, you could always use Donkey Dicks if you want to expel your exhaust under water.
SB is offline
