Go Back  Offshoreonly.com > Owners Forum > Sunsation
288 Sunsation with no Fridge but want one. What do I need? >
Old 09-16-2015 | 04:08 PM
Default 288 Sunsation with no Fridge but want one. What do I need?
Hi, mint 2002 with no fridge. I would like to add one in the cabinet. I think it would fit. Do I need a acdc fridge. Works off batteries, then flips to shore power. What do I need? Would also like to add shore power. Plus, where do I buy the coolers for under seat.
248-892-7202
Shane
Michigan
Wrecking it is offline
Old 09-17-2015 | 07:10 PM
The coolers are most likely from AO Coolers. www.aocoolers.com
Sorry I can't help with your other questions.
Scagburner is offline
Old 09-17-2015 | 10:14 PM
That helps thanks
Old 09-21-2015 | 12:35 AM
Sydwayz's Avatar
Forum Regulator
Are you sure you want a fridge? They really are not built to withstand the kind of beating that go-fast boats endure.
Sydwayz is offline
Old 09-21-2015 | 12:26 PM
248-892-7202
Shane
Michigan
that boat came with a pair of Coleman "personal 16" coolers that fit into the floor:
http://redneckstupid.com/diy-to-go-keg/
(minus the redneck engineered beer tap of course)
Sunsation later switched to the aocoolers, more of a bag type cooler with the Sunsation logo on the side.
You might want to see one of those refrigerators in action before you retrofit......if you had a choice of a beer from one of them or a beer from a cooler full of ice......you would take the latter! Those fridges are "chillers" at best.
Jupiter Sunsation is offline
Old 09-21-2015 | 02:08 PM
The fridges are worthless. I have had them in a couple boats and they never get used for anything more than a cabinet. Don't waste your time or money.
wfo1 is offline
Old 09-21-2015 | 03:21 PM
i agree with some of what was said above I have a fridge in my 32 Sunsation and love it...we use it for food and it eliminated a third "food cooler" . It does get cold if I hook up the shore power over night but if your looking for frosty cold beer just by turning it on when you hit the water you will be disappointed.
bigredbaja is offline
Old 09-22-2015 | 01:00 PM
We installed Norcold fridges in the wetbar. They were powered off 12 volt or 110 with shore power. They get cold, but you'd have to run it a long time. Lot's of people end up taking them out or never even using them. I know there are some higher end fridges out there, but this is the only brand we ever used.
Jeff Sunsation is offline
Old 09-29-2015 | 04:45 PM
Jeff, do you know of any or have used? I am local to you. It would make the wife and others happy. Lol would love to see the place sometime.
248-892-7202
Old 09-30-2015 | 05:57 AM
248-892-7202
Check these links.I think one of these fridges would work. The last model we used was DE-0751. (I think the NR751 is the new version) You should be able to buy it direct.
http://www.thetfordmarine.com/product/nr751/
http://www.thetford.com/product/0041/
