Engine Stumble at 2100 RPM
Twin 502 Cu In. Gen VI big blocks
Stock motors 450 HP at the crankshaft.
In 292 Formula SR1
Problem :
Getting up on plane I have a stumble in both motors at around 2100 rpm's getting on plane.
It is not an overpowering stumble and goes away quickly.
I do run high test gasoline .
Fresh spark plugs gapped.
Timing on the money
New Cap
New Rotor
Wires good.
Holley dual feed 850 double pumper carb.
I have had this problem since I repowered several years ago.
Once I get passed the stumble the boat runs perfectly.
I have both motors out and are about to toss them back in someone said I should figure out what jets are in the carb now and buy the next two size up jets.
Toss in the next size and see what happens.
My spark plugs were not fouled at all and their color was dark brown !
Does anyone on here have any suggestions.
Thank you in advance for the reply !
Big Boys Toys
In 292 Formula SR1
Problem :
Timing on the money
New Cap
New Rotor
Wires good.
Big Boys Toys
if they are stock engines then they are only around 8.2:1 compression so stop running hi test. the engine was designed to run on 87 octane. anything higher and they actually lose power as the fuel will not burn completely.
I have seen it on a Rochester with a little corrosion the power valve would stick and do that. Different power valve design so I would say not corrosion. Try a bigger power valve and see if it gets better or worse
