Stagger Question
Old 09-26-2015 | 10:19 AM
Default Stagger Question
I am curious to know what the prop to prop center line is on short stagger . My side by side set up has a 36 inch center line to center line , I believe a full stagger has a 20 inch C/L to C/L . Does any know what that dimension is on a short stagger ?
Rick G.
Rick G is offline
Old 09-26-2015 | 11:19 AM
I believe full is typically 18-20, short is 22-24
Unlimited jd is offline
Old 09-26-2015 | 02:11 PM
14 apache's Avatar
My 41 apache is 18" And I think short is 24".
14 apache is offline
Old 09-26-2015 | 02:42 PM
Team Archer's Avatar
We have been setting up all of our staggers at 21 Center Lines. Short stagger is as close as you can get we set the motors on the ground to see how close we can get with the length of the engine room.
Team Archer is offline
Old 09-26-2015 | 04:12 PM
glassdave's Avatar
Neno the mind boggler
how much engine length do you need for a short stagger? I really would like to do some kinda stagger on my 38 Scarab Thunder
anyone have any pics of a short stagger setup?
08 OPA High Points Champion
glassdave is offline
Old 09-26-2015 | 06:22 PM
Dave I know the typical bilge for a full stagger is 100 inches . I am thinking of staggering the a Flat a Deck without losing most of the cockpit so a short stagger may be the way to go . I am thinking I can do it 80 inches or less that way I don't lose too much of the cockpit but as Dan said need to lay out first see just what the fit will be .
RG .
Rick G is offline
Old 09-26-2015 | 07:13 PM
It also depends on what drives you plane to run. you can do a full stagger with bravos in 80 inches, speedmasters you need at lease 96 inches short stagger you can gain some room by putting the starboard motor forward but it all depends on your accessories package. I have done it both ways
Old 09-26-2015 | 09:48 PM
bck's Avatar
bck
Charter Member#568
Dave, my boat that you worked on was a short.
Attached Thumbnails Stagger Question-102576d1098810631-sweet-100mph-38-larry-smith-scarab-scarab-engines.jpg   Stagger Question-imag0781.jpg
Straight bottoms and flat decks
bck is offline
Old 09-26-2015 | 10:06 PM
bck's Avatar
bck
Charter Member#568
Can't really get much closer with the transom assembly's. I can measure whatever you want. Mine is about as tight as you can get.
bck is offline
Old 09-27-2015 | 12:34 AM
Bck what is the distance from the transom to bulkhead ?
Thanks R G .
Rick G is offline
