Did I Get A Killer Deal? >
Old 09-28-2015 | 06:52 PM
Question Did I Get A Killer Deal?
1996 302/OS paid $19,250 w/ 2009 Aluminum 3 Axle trailer, surge brakes.
Compression test done 454 MPI's 160's (1), 170's (2), full survey done issues below.
In addition to the options in the link below the boat has pop up cleats, shore power, new batteries, flush out potty, 271 total hrs. on hull and 1 engine, 30 hrs on the other.
It needs, horn inop, 4 engine tab solenoids, trim tabs. inop., 12v bilge pump & float switch, Refrigerator, rear seat structure is soft/vinyl good, headliner is stained (replacing), cabin carpet is stained (replacing).
Other than the vinyl work I get all the parts at cost incl. fridge and a buddy who is a boat mechanic by trade and I do all our own work. Even at retail look like $5k worth of work.
Clicky ---> http://i179.photobucket.com/albums/w...psiyicgcuz.jpg
Tractionless is offline
Old 09-28-2015 | 07:50 PM
t500hps's Avatar
21 and 42 footers
Doesn't matter what we think. You already bought it and seem happy with it. Follow your plan and enjoy the boat.
BTW. The 454 mpi's were 310hp if it matters.
t500hps is offline
Old 09-28-2015 | 10:19 PM
Fix the leaks that prob disturbed the old liner , if your pulling it out , .vortec mpi's arent barn burners but start good use a bit less gas than contemporary carb sub 20k twins , just dont let em freeze.
airjunky is offline
Old 09-28-2015 | 10:22 PM
Seal the bench to the floor and toss in a drain if its not already there then seal the seat if subs are there will sound worlds better ,alot easier when its apart. Sounds like alot of boat for 20k
airjunky is offline
Old 09-29-2015 | 06:39 AM
It kinda does to me as being a 1st time boat owner I'd like to know what the more educated on the subject feel. The engines should push it into the 60's which for the majority of the use being river and intracoastal will be plenty.
S. Florida, no freeze issues, thanks!
Drain in the cockpit floor or under the seat? Thanks
Old 09-29-2015 | 02:11 PM
congrats, pictures of the boat please
Brandonb_05 is offline
Old 10-03-2015 | 09:29 AM
It depends, we need him to clarify. 454 mpi is 310, 454 mag mpi is 385
Baja226sport is offline
Old 10-03-2015 | 09:30 AM
Let's see some pics
Old 10-03-2015 | 01:46 PM
How do I tell the difference?
Let's see some pics
The boat will not be in my possession for 2 more weeks. Its going directly to the upholstery shop 150 miles away to get freshened up.
Old 10-03-2015 | 04:13 PM
7.4 MPI 310 hp
