Seems like these two boats could merge into one great boat for 100K! >
Old 10-05-2015 | 08:27 AM
Default Seems like these two boats could merge into one great boat for 100K!
http://www.offshoreonly.com/classifi...-s-o63078.html
Baja with 900's and #6's......
http://www.offshoreonly.com/classifi...03-o63465.html
Outerlimits 47 GTX with no power.....
I certainly do not have the know how to swap the power but there are plenty of folks on here that do! 900's wouldn't be the fastest OL 47 out there but it still should break 100-105 right?
Jupiter Sunsation is offline
Old 10-05-2015 | 08:58 AM
Ran-Dom 32's Avatar
That is a great idea.. both boats are in Canada as well... hmmm
Ran-Dom 32 is offline
Old 10-05-2015 | 09:08 AM
I'm no expert. But, it won't be that easy. Motor mounts and exhaust from the Baja most likely won't work on the GTX. That's just the 2 most obvious "added" expense. But, yes I agree that is the way to do it..........having a complete donor boat.
benjen is offline
Old 10-05-2015 | 09:09 AM
and the Canadian dollar is depressed about 25% off the US dollar value, plus summer is over/winter is closing in........will be a nice project with 100K and some know how!
Old 10-05-2015 | 09:12 AM
You would probably want to refresh the power/drives before install anyway so you would probably want new exhaust to start with. Of course the transom assemblies might not want to come apart, could be rotted and the drives could be milkshakes in the making but you might get lucky and have to source minimal parts.
And you have 83 ft of projects waiting for your every spare minute/dollar!
The Baja could be sold has a hull project to recoup some of costs.
Old 10-05-2015 | 09:13 AM
Are they wet or dry sump 6s?
JRider is offline
Old 10-05-2015 | 09:24 AM
It will only run 100 mph with 900's? Really? Shouldnt it run 95 with 700's?
Keith Atlanta is offline
Old 10-05-2015 | 09:37 AM
Bostonirish's Avatar
It's an old school resin gtx . If those motors are freshened up that boats good for 110 is my guess.
Bostonirish is offline
Old 10-05-2015 | 09:51 AM
Going off memory.....XXX was a light layup version of this boat and ran 125ish with 1075's. The newer Merc stuff seems to put out more HP than advertised, not so sure about the old 900sc's. So with 400 less HP and a heavier layup on an older twin step design I don't see it running any big numbers but it would surely look good at any speed!
Old 10-05-2015 | 10:11 AM
F-2 Speedy's Avatar
Those headers should work fine with new tails,
F-2 Speedy is offline
