Engine rebuilders in the Chesapeake region. >
Old 10-06-2015 | 08:23 AM
Default Engine rebuilders in the Chesapeake region.
I have 500 EFIs with over 500 hours on them. I am looking for recommendations for local engine builders that someone has used and had either good or bad dealings with. Yes bad dealings so I know to stay away from and good results to maybe check them out further. I can pull the engines to maybe help out thier shops schedule.
fordf350 is offline
Old 10-06-2015 | 09:35 AM
Call Tony @ CMS 410 335 2226 try calling early in the morning. Otherwise leave a message and he will call you back. He's very good a little slow on return time but he's honest about time frame. In the end you will be happy.
Black Baja is offline
Old 10-06-2015 | 11:31 AM
Mark Rinda at MER performance is out that way
MILD THUNDER is offline
Old 10-06-2015 | 11:54 AM
If you consider 8 hours drive out that way.
Old 10-06-2015 | 12:06 PM
dcb
Dont forget Dave at MDG.
dcb is offline
Old 10-06-2015 | 01:59 PM
Boater8987's Avatar
Airking
+1 = Good at 410-956-5381
Boater8987 is offline
Old 10-06-2015 | 07:05 PM
+2 for Tony at CMS Racing, he did the motor in mine
ealesh33 is offline
Old 10-07-2015 | 08:20 AM
Going to check out each one of them thanks guys
fordf350 is offline
Old 10-12-2015 | 09:04 PM
Ok I think I have found a rebuilder. So my next question is do I pressure test the headers and reuse them or buy new ones?
fordf350 is offline
Old 10-12-2015 | 09:25 PM
What does your rebuilder say?
