gpm of water to run a mercruiser on hose >
Old 10-07-2015 | 12:52 PM
articfriends's Avatar
Default gpm of water to run a mercruiser on hose
Putting in a dyno at my shop plus wanting to run boats on hose from well pump. Current pump cant keep up so going to have a new well drilled. How many gallons per minute should i be looking at fory new pump, thanks, smitty
articfriends is offline
Old 10-07-2015 | 01:04 PM
SB
Congrats on your soon to be new Dyno !
I have no hard data for you but I emptied a commercial 250-300 gallon stainless 'sink' within a few minutes with Bravo pump on a dyno. With garden hose still running in to the 'sink.'
So, lack for a better measurement, around here, we'd say you need more than a schit ton. LOL.
SB is online now
Old 10-07-2015 | 01:15 PM
Dynos not new, norm schenk from competition fuel systems in tuscon arizona just moved to my town and we are putting it in my shop as a partnership. I guess more than running a boat on a hose, we need to be able to run a motor at wot and not run out of water
Old 10-07-2015 | 01:29 PM
SB
So...as an option like I did, I bought a used sink or wash tank or whatever that held that much water. I hooked the drain up to the inlet of the sea water pump. Issue is that it takes a bit for the garden hose to fill it. LOL. Good news was, that it was halfway easy to move outside so it wouldn't be in the way when not needed.
Good luck with the partnership !
SB is online now
Old 10-07-2015 | 01:39 PM
I like that idea, could tee a garden hose in like a flush line in the boat to start it and warm up, then close the flush make pulls off the tank.
Unlimited jd is offline
Old 10-07-2015 | 01:41 PM
Norm is a soft spoken engineer type who worked at university lab in arizona grinding telescope lenses for nasa, he is quoted in the holley carburetor book as a carbb expert, he uses the dyno for testing and developmental work, i get to use it as i need at no charge in return for giving him shop space, we are excited
Old 10-07-2015 | 01:47 PM
Sounds great Smitty! your building quite a nice shop there Sir! hope to get by and visit with you again soon.
abones is offline
Old 10-07-2015 | 02:47 PM
Good thing I have the perfect test mule for you hehe......
Gimme Fuel is offline
Old 10-07-2015 | 03:04 PM
Smitty, i wanna say somewhere in the neighborhood of 2500 gallons per minute would be needed
MILD THUNDER is offline
Old 10-07-2015 | 03:16 PM
BUP
Merc has testing for engine side and water discharge output water volume of the water pump impeller / housing / water flow thru to the sea water pump outlet side.
Basically OEM stock bravo set ups and depending on closed cooled or not and other examples - big block or small block apps
with that said OEM stock bravo the general rule of thump Merc spec is called
SEAWATER PUMP OUTPUT TEST but the boat must be in the water (MERC specs) or IMO a huge bucket of water under the outdrive.
engine ran at 1000 rpms - sea water pump outlet hose off as another hose long enough installed then set in a large enough empty bucket - MERC basic rule of thumb for bravo apps is 15 seconds of run time at 1000 rpms needs to fill the bucket 10 qts of discharge water bare min.
BUP is offline
