Livorsi Control Problem
Anyone replaced the built in trim switch on a Livorsi side mount control? When trying to raise the outdrive, the up side will intermittently just click a few times and finally start working. Down still works fine. Haven't tried to take it apart yet, just wondering if anyone else has had the same or similar problem. Does it have a relay installed? So far, I haven't found any info on this shifter.
If so, do you have to order from Livorsi, who has discontinued production of this shifter, or have you found it elsewhere on the web?
No, not sure at all. I assumed (and everyone knows what happens when you assume) that it was not the solenoid since the switch, when pushed in the up position, clicks each time you do it. Usually about the 3rd or 4th push/click it starts working again. I guess it could be the solenoid, I just don't know. Maybe a poor connection at the pump? Have had the connection come completely off before and trim did not work at all. Plugged it back in and worked fine. Will check that also.
Sent Livorsi an email with a picture last night to see if they had any leftover switches available. Looking on their site, it seems there may be at least two different types of switches that they have used for this control. Hope to hear back from them Monday or Tuesday.
If you happen to need a Livorsi trim switch, I have a new one sitting around .
