454 making 525-550hp >
Old 10-15-2015 | 07:03 PM
Default 454 making 525-550hp
I have a merc 420 in my Formula 242. It has TRW2399 pistons, crane 132561 cam, dart single plane intake, Holley 800, EMI tunder with 3inch taller/long tails. I run 62mph@5000rpm now with a 23p mirage. I would like to hit 70. I have been told I need 525-550hp to get there. Do I just put a 177 on it? Can I just cam it? I have searched a bunch and the results are vague on the builds people get with 454s. I know this may not be accurate, but on desktop dyno i got 516hp with only a swap to a 741 cam.
79formula is offline
Old 10-15-2015 | 07:09 PM
You will need to add 150hp to it to get to 70. I would think that a blower would be the easiest and most cost efficient way to get there.
snapmorgan is offline
Old 10-15-2015 | 07:15 PM
Thats kinda the way I am leaning. I can pick up a 525sc blower/carb setup for $2150 shipped. I am thinking I might make more than a 525sc as my compression is a bump higher. FWIW The previous owner had a 530hp motor in it, he claimed low 70s.
Old 10-15-2015 | 07:22 PM
From what I have personally seen, at those speeds with a single engine it takes about 20hp to pick up 1 mph
you'd need to work over the cylinders pretty good(porting) and at least a cam in the 230,236,ls112 range w/ around .600" lift and compression in the mid 9's.thats whatI did to get 527hp,517tq from old 420's.I also ran a victor jr. w/ a bolaw's 950 carb.
sutphen 30 is offline
Old 10-15-2015 | 07:26 PM
Sounds like a $10,000 project to me before all is said and done.
Black Baja is offline
Old 10-15-2015 | 07:41 PM
Could I mill my heads to bring the compression up and throw this roller cam in?
http://www.summitracing.com/parts/hr...make/chevrolet
Old 10-15-2015 | 07:46 PM
I rather see you run an hp500 efi cam,,230,236 or put a 741 in,,do you have dry exhaust?
well we could start w/ some profiler oval ports.
Old 10-15-2015 | 07:50 PM
I have EMI Thunder with 3" additional rise.
